Help Why Night Shooting Sucks?
TheOneGuy
Member
At night i often get bad quality when shooting. No matter what resolution. However with flash quality gets better. Without flash you can see distorted picture.
See this album
Upper picture is with flash and below picture is without flash.
Is this with all Android based devices or with iPhone too?
By bad quality I assume you're talking about the grainy texture of the image, right?
Unfortunately that's something you have to think about with any camera. It's caused by the phone increasing it's sensitivity to light to compensate for the dark conditions.
Try playing around with the 'ISO' (sensitivity to light) setting rather than leaving it on auto, you might be able to find a better compromise.
Thanks Xyro.
Do you think this lens will work with HTC Desire S?
Assuming your phone has a 13mm lens on it then I don't see why not. I can't say I've ever used one of those attachments however.
I had a quick look on google but couldn't find anything. Might just be easier to measure your phone :)
When they said 13mm lens, they had in mind metal ring included too? How is lens measured on HTC Desire S correctly? With metal ring or without?
