B
Basic Android OS
Guest
I'm still waiting an update to Samsung GT 4 7.0 and GT 2 7.0.
I want to get rid of the absolutely stupid restriction of Android 4.4 in using the SD card.
We are waiting until Samsung has managed to modify their bloatware for the device.
Is it really impossible for Google to build a version , which fits to any tablet and phone ?
It can work so that Odin reads the model of the device, downloads the drivers and kernel from the network to the PC and builds the filesystem.
This packet can then be uploaded to the device.
If need be, the bloatware can be loaded as separated apps.
Android must return back to the roots and check how things are made in Linux. You can always find or build a version of Linux, whis works in your iron.
I have nothing against ads, but this Android 4.4 is totally braindamaged. Preventing me using my SD card made me check if I should move to Apple or even M$win (yak). In Apple you can use no memory card, so forget it.
As long as roaming prises are so high, you got to use your maps offline. And in the bush you do not have a network.
