Can somebody explain why there still is so big differences in battery life between many different handsets which each of has the exactly same SOC and same OS...? Look at the reviews at the end:
There is 4 phones, 3 of them have almost the same size display and same SOC but there is dramatic difference in battery life. E.g. web browsing life:
LG G2 11:22h
Galaxy Note 3 9:04h
Sony Xperia Z1 5:59h
LG Nexus 5 4:46h
Especially puzzling is that the best and worst handset is from the same manufacturer (LG)!, and the best has 2.4x more battery life.
I have understood that it has to do with software optimizations and perhaps drivers. Do G2 and Nexus really have that different optimizations and drivers even that they are from the same manufacturer...?
How about if you root your phone or install a custom ROM? Would the epic battery life of G2 drop to the same level with Nexus5...? Isn't it likely that both would use same optimizations/tweaks/drivers in a custom ROM...?
If you are going to install CM or other customROM do the battery life tests (that are done with stock ROMs) give you really any added value? In otherwords, the optimizations that give epic battery life to LG or Samsung phones, are they also present in the customROM side...?
I mean Nexus5 seems to have a very poor battery life, and with non-removable battery it really does not encourage me to buy one.
The Sony Xperia Z1 battery tests are done, here's the score - GSMArena Blog
LG Nexus 5 battery life test - GSMArena Blog
Samsung Galaxy Note 3 battery life test - GSMArena Blog
LG G2 battery tests are done, here are the results - GSMArena Blog
LG G2 11:22h
Galaxy Note 3 9:04h
LG Nexus 5 4:46h
