Root Why won't my changes in framework-res.apk load?
CJP
Working from rooted 2.3.3 (on a Droid X2, but I don't think that matters).
I have pulled /system/framework/framework-res.apk from the phone, unzipped, modified exactly one file (\res\drawable-hdpi\zz_moto_list_texture_bg.png) with photoshop, zipped back up (7-zip), zipaligned and pushed back into the /system/framework/ directory with the correct permissions. The file was not re-signed.
The phone boots without error, but the new modified file does not get loaded, the old version of the graphic remains. I have double checked and my modified /system/framework/framework-res.apk is in place. I don't know where the phone is getting the old version from.
I have tried formatting the system cache, erasing all user data via android recovery, zipped with different levels of compression for the apk file (moderate to none), same result.
I had this problem before on 2.2.2, which I thought was corrected by formatting the cache, but I guess I was wrong and it got fixed by chance. :/
Does anyone know what can be done to force framework-res.apk in the /system/framework/ directory to load?
Relevant files attached.
Chris
as soon as you unzipped it, you broke the signature. try using 7 zip to just pull out the image you want. edit it and then stick it back in without unzipping anything.
