Why you shouldn't under volt or over clock...
ironass
Extreme Android User
Aug 17, 2010
12,772
6,356
Cotswolds, England
This a copy of a post from a chip designer, Vikas Mishra, of some 14 years, who has posted this on the Dorimanx xda thread but his statements apply to all kernels.
I think, with his credentials, it is well worth reading this as it explains why u/v'ing and o/c'ing are not necessarily good things and also why one person may, or may not, find a particular kernel/settings are good/bad for their phone/chip...
"Hello people.
Let me introduce myself - my name is Vikas Mishra and I am a chip designer by profession. .
I have worked on critical parts of design of TI OMAP4, OMAP5, Nvidia Tegra 3 etc and have been doing this for the last 14 years.
Of late - I have seen a lot of folks posting BUGS about undervolting of the GPU/CPU.
I think I can explain what are the possible issues with undervolting/overclocking in a laymans language.
It is a little long winded but I think the length is needed for providing the appropriate context.
* What is inside your Cellphone
Your cellphone is an amazing device. It is a full fledged computer
that fits into your pocket. They have all the standard components
that a computer has - except that they are all usually soldered on
the motherboard directly and are not meant to be user-servicable.
The chief components inside your cellphone are
1. Application Processor (AP)- this is the heart of a modern
cellphone. These are manufactured by many companies - the main
ones are Qualcomm, Nvidia, Samsung and Apple. The other not so
well known ones are made by Texas Instruments, ST Ericsson,
Marvell and Broadcom.
A modern AP has logic to control the camera and process the image
that it generates, to do video encoding (video recording) and
video decoding (movie watching), Audio processor etc. in addition
to the well known CPU and GPU.
2. Power Management Controller - This is the chip that is
responsible for generating and regulating the voltages that are
used by all the components on the board.
3. DRAM - not very different from the DRAM found on a PC (except
that it is lower voltage)
4. Flash - for storage
5. Touchscreen controller
6. Logic for microphone, speaker
7. Battery
One of the most complex piece of circuitry on the phone is the AP
and the power management controller.
* Circuit Basics
A modern AP has millions of circuit units called (Flip
Flops). These flip flops have two parameters associated with them
called Setup time and Hold time. More details on what a flip flop
can be found on the wikipedia at
http://en.wikipedia.org/wiki/Flip-flop_(electronics) . This is a
nice bit of bedside reading if you are interested.
A setup time roughly indicates what frequency you can run a design
or an AP at before it becomes unstable.
A hold time roughly indicates the maximum voltage till which a
design is stable.
A fully technical analysis of what is involved in these timing
parameters requires a degree in electrical engineering but in broad
terms the problem is described below.
Chip designers diligently ensure that all of the millions of the
flip flops in a chip meet the setup and hold time across a broad
range of voltages and silicon parameters. They do a pessimistic
analysis to ensure that a chip will run reliably across a wide
range of voltage/frequency combinations.
However, contrary to the popular belief, chips vary widely in their
silicon parameters. Even chips on a the same wafer and different
flip-flops within the same chip can have widely different silicon
parameters. This is why what works on one particular chip will not
work on the other chip.
Your silicon manufacturer provides a range of voltages and
frequencies across which the device can work reliably. The phone
manufacturer will further narrow down the range depending on the
other components they choose within the phone board.
* How does voltage affect the design
Reducing voltage makes the design slower and increasing voltage
makes the design faster.
So can I keep on increasing the voltage for ever and make the
circuit faster and faster. The answer is no - a point will come when
the circuit will become unreliable. This becomes unreliable because
the "hold time" of one or more of the flops will start
violating.
As you reduce the voltage of the design, the circuit will start
becoming slower. However typically it will continue to work till at
apoint it starts failing - this failure occurs due to violation of
"setup time" of one or more flops in the design.
So what happens when the setup time or the hold time of a design
fails - the answer is that it is unpredictable. Meaning suddenly if
you ask the processor what is the value of 2+2, the answer it will
provide could be unreliable - in some cases it could be 3, in some
cases it could be 4 in some cases it could be -2349783297 (a random number).
I am of course oversimplifying but I hope you get the picture.
* How does undervolting affect your phone processor
The reason undervolting is so appealing to people because they
thing that undervolting will save power and improve battery
life. While this is true in theory, in practice there is a caveat.
It will reduce the power of the chip, but the power consumed by the
phone as a whole will not improve. In some cases in fact it can
deteriorate. Let me explain.
The most power hungry part in the phone is not the AP - it is the
LCD screen. All of these screens consume a ton of power. So even
though your AP is now consuming lesser power, the overall impact to
the phone as a whole is not that much.
If you accompany undervolting with a frequency reduction (which you
should), the total time taken for doing a web page rendering (for
example) would increase. During this time the screen is on and it
has more than compensated for the power that you saved in the
AP.
You could of course come up with examples where this wouldn't
happen - but on a whole, IMHO, you should leave the voltage of the
AP/GPU/CPU to the guys who know the system best - the guys who
designed the chip and people who manufactured it.
* How does overvolting/overclocking affect your phone processor
If you want that last drop of performance from your phone and you
over clock it, at a point some of the design flops will start
violating the hold time and the design will stop working reliably.
Again, in some anecdotal cases this would work - but this is not a
reliable means/mode of working. Just because your friend's or your
first cousin's girlfriend's phone works - doesn't mean yours will
work as well.
* What are the user observable impacts of undervolting/overclocking?
It is hard to say - simply because there are so many of flops in
the design.
In some cases - you wouldn't see anything wrong with the phone
until one day you do. In some cases it will result in a SOD
immediately. In some cases it will result in your phone not waking
up reliably.
IMHO the risks of issues with undervolting/overclocking far
outweighthe potential gains you may get out of it. Usually there
is no lasting damage to the phone/AP if you overlock/undervolt but
it is possible to do it. For example, You run the phone at such a
high frequency that the chip temperature becomes more than what it
was designed for and the Silicon just fails.
So "Just say No" . Don't overclock or undervolt your phone -
leave it to the guys who really understand what they are doing.
Thanks,
Vikas
I believe this is very device specific. I overclocked my Droid (stock 550Mghz to 1.2Ghz) for a year and a half; undervolting the whole time. Never saw any problems. It struggled towards the end of its life due to such little RAM.
Some phones can be OC'd easily without little problems, but most likely shouldn't.
Upvote 0
I do not think that it was intended to be device specific dreadnatty08 but rather an overview of chips in general.
It would seem that you were one of the fortunate ones, as he points out...
up reliably.
I think what he's getting at is that if you do u/v or o/c, then don't be surprised if you do get an SOD, FC or freeze and certainly, don't blame the kernel.
Upvote 0
At least this explains Syd's Kiss Of Death where kernels are concerned.
It also means that we can all point to this the next time someone posts...
"What is the best kernel and settings for me to use?" :shot:
Reply... "Whichever one works best for you!" ;)
Upvote 0
anyone got any guides on overclocking S2?
If, after reading everything in post #1, you still wish to overclock your phone you will need to be rooted and install a custom kernel, such as Siyah along with ExTweaks and then you can use the Scaling_max_frequency in ExTweaks to push the upper limit from 1.2 to 1.5 GHz, or more if the kernel will take it.
Upvote 0
Interesting article ironass. I used to overclock my old Nokia N900 and read a similar piece ages ago. It's dead easy to O/C on the SGSII and the adage of just being able to do something doesn't mean you should holds very well.
I have O/C my SGSII, but not by much, you can fry (literally) your CPU overclocking and it isn't unknown. Certainly making it run faster than your CPU is set for will shorten it's life.
Upvote 0
This is a great post, although he does not take into account that some manufacturers actually underclock the device to begin with so in theory overclocking should not effect stability, only battery life.
For example, the sgs2 runs at 1.2ghz where as the note runs at 1.4ghz. Both using the exynos 4210 soc. The same applies to the sgs3 and the note 2. Sgs3 runs at 1.4ghz, note 2 runs at 1.6ghz both using exynos 4412 soc.
Upvote 0
BEST TECH IN 2023
Smartphones
