Hey all,
I just got my Nexus S and I'm trying to connect to a wireless network that has multiple routers.
Specifically:
Cable Modem -> WAN Port of NETGEAR Wireless Router -> (lots of cat6) -> LAN Port of Linksys Wireless Router
I'm connecting to the Linksys which is basically acting as a switch, although I do have a different SSID for it. Both are using WPA2 albeit with different SSID/passwords
I'm trying to connect to the Linksys router. All of my other devices connect to it fine, and my phone gets an IP, I can ping it from my computer, but I can't access any sites from the phone. The Wi-Fi bars are white, instead of green. I can connect to the other router fine, but its too far from my room to use unfortunately.
Any suggestions for this very specific issue? Thanks, first time Android user so I'm looking forward to hanging around here a bunch
Specifically:
