Help Wi fi keeps dropping out, why?
DCTEN
Hi,
Does anyone know why I'm having to keep going into my settings and having to keep re connecting my wifi? Having to do this every 5 minutes! Very annoying! It'll be fine for a few mins then things slow down on the browser and I check the settings and its stock on the ' authenticating' process bit! Arrrrrrrrggggh!
WiFi is a bit of an issue with the first release of Gingerbread. Try assigning yourself a Static IP or turning off 3G whilst connected, see if those make a difference.
Instructions are here.
Are you branded? HTC have patched the issue so if you've no network logo etc, you might have another update waiting?
That's obviously presuming it's the GB WiFi issue.
Root it and sort it for good while improving wifi performance in an epic way....lol I am the voice of the little devil on your shoulder...;)
When I forward internet via wifi to my computer I often see the computer renewing the connection. I suppose this is a related problem. I have an unbranded phone and 2.50.405.2
