WI-FI Optimisation issue
james_uk
Hi, I noticed that in the advanced wifi settings is a setting for wifi optimisation which says it saves battery.
I am finding that when this setting is on, every time i am on a game i am getting messages says lost connection and my games having to reset or start again, when the setting is off this doesn't happen.
the option does actually seem to save a lot of battery i have found, but its a shame that i keep getting disconnects with it turned on :(
has anyone else found this?
thanks
James
"Optimization" means that if the card hasn't actively been used for a while, the computer (phone, in this case) can turn the card off. If you're browsing occasional web pages that can save a lot of battery. If you're playing a FPS, that can waste a lot of your lives.
