Help Wi-Fi problem
redvolvo77
Just a quick question for everyone that has done the OTA update. Is your Wi-Fi- working. Mine will not scan for networks and just turns the wi-fi- off. Thanks guys and gals!
try rebooting couple of times...the update doesn't seem to apply changes in one go.
I had the same issue once. Scanning for wi-fi networks showed none even though there were wifi signals around. I had to do a factory data reset on the phone to fix it.
A couple days ago I my wifi stopped working.
My phone is rooted, and this is what I did to fix it:
Get the USB drivers from Samsung: they work for me on Win7 x64
Download the Android SDK Android SDK | Android Developers
Connect USB to phone with USB Debugging ON (Settings/Applications/Development)
On your computer open a Command prompt (I ran as administrator)
cd to SDK install directory
Code:
cd tools
adb shell
su
- This means "switch user" and elevates your command prompt to root. A prompt will come up on your phone and you need to allow it to run
- Also, this means you are running as root, so be careful, not my fault and whatnot
Code:
cd /data/wifi
mv bcm_supp.conf bcm_supp.bak
-you can look at the file first if you want, just type "cat bcm_supp.conf", it is the "secure credential storage" where all of your wifi SSID/passwords are stored in plaintext
Code:
reboot
-When your phone comes back up, wifi will once again work.
Hooray!
I found the answer here:
[Q] WiFi issue (unable to scan networks) - xda-developers
Also, thanks to http://androidforums.com/captivate-tips-tricks/124738-how-enable-sideloading-apps-captivate.html
I installed that update too and the same exact thing happen. You're not the only one buddy. Hopefully they fix it soon and we'll get our wi-fi back.
Since the update I have to manually turn off and on my wifi at the house. It'll be on but not connected. Turning it off and on helps.
I found this article that gave me a complete how to, from start to finish. I am a novice and I was able to complete the steps and get the wifi back up and running. The earlier post gives the info if you have a rooted phone, but I did not, now I do. Samsung Galaxy S wifi fix
I hope this helps someone else.
