Root Wi Fi Tether Problems
money15
I cant get wifi tether for root users to work after JB update anyone else have this problem?
i get an error when i turn it on and it keeps asking for root rights even though i tell it to remember to allow...anybody got wifi tether to root with B11?
Edit: Switched to superuser app by cwm and it seems to work now
wifi tether for root working here. i am using ChainsDD Superuser. No force closes here. All that has been fixed for a while lol
Yeah I never had force closes just started with errors....got it working with superuser by clockworkmod I like it anyways nice interface
i was using that on b09. I thought it was nice as well. However, it seemed a little slow to open the access screen when a new app wants root. glad you got it working ;)
Turns out it didn't work never tried it with another device it isn't broadcasting huh I changed the proxies in hidden menu to zeros u think that could be a problem? I got to look at my last wifi tether Thread and check what ur settings were for the app lol
Ok I REALLY Got it working this time thanks Super for trying to help me out....it was something in the app settings i believe not really sure what but im not touching it Again haha....darn app haha
ok i solved the problem first you need to go to settings on wifi tether
change divice profile
generic ics/jb (wlan0)
fallback tether
check this option
wifi-driver reload
check thisoption
and last
wifi-driver reload 2
check this option too and your good to go
if you dont do this the tether migt show no errors but it wont give you a conecction i just tested and im posting this post whit the internet of my cellphone
also try to download wifi tether version 3.3-pre2 ***EXPERIMENTAL*** thats the one i have rigt now
here is the link
https://www.dropbox.com/s/1v8rlsh9qtqppi7/com.googlecode.android.wifi.tether..apk
can someone pm me the chainsdd superuser app to flash in cmw. i still cant get this tether to work on jb. i have tried everything but chainging su apps
fallback tether
check this option
wifi-driver reload
check thisoption
and last
here is the link
While I appreciate your posting this, I'm still experiencing (with this new version) not being able to gain actual tether. I've tried your setting's just don't see what I might be missing.
The log that's available, show's more red errors failure messages and only a couple success's.
The Nexux 7, does the same with this version as with the previous version, it LOOKS like it's tethered, it's show's as tethered, and say's it's got excellent strength ...just no tethering happening.
Ever since updating to B11, tethering doesn't' work,... before? not a problem. So, any idea's are appreciated.
Okay so i switched su apps and it took care of most of the issues,now the only error i get is mss clamping failed, and that prevents my ability to tether aparently
Combined two screenshots to show the entire log after the attempt to tether using WiFi-Tether 3.3 experimental.
It's got the expanded menu that xxpaco talked about in his post above.
I was getting the same errors using the earlier version for the last 6 months so that alone is informative. I tend to think it's something about the B11 OTA update, as apposed to anything else at this time.
Maybe it's a simple setting issue, but what?
ok here is one more setting to aply hope it works for you
got it from rush forum from Lordvincent 90 got jb on rush same problems this fixed the problem
device profile
setup method
auto
send net max client cdm
cheked
wifi driver reload
cheked
routing fix
cheked
try to use the super su app
ok try this settings and let me know
device profile
setup method
auto
cheked
wifi driver reload
cheked
routing fix
cheked
Wow, I'm still needing to clean up, there were so many threads on this topic, and this is the second one I forgot to go back to and post that
I did get tether working again.
I also had to replay to a followup on the Nexus7 thread, WI-FI Tether errors. Because I tether that tablet with my phone, went there.
And #18 on this thread: http://androidforums.com/warp-sequent-all-things-root/743381-wi-fi-tether-errors.html#post6011943
There's this: Can't Tether after the OTA But I might be getting conflused about now and duplicating.
In my case it was SuperSu that needed to be replaced, so got SuperUser, instead, problem was solved. There had been an error message that binaries were out of date, and after getting SuperUser no more problem, except in the log, getting an error for "clamping" however that doesn't prevent tether for me.
Anyway, thanks for checking in with your solution, there's a good chance someone will need it.
