Help Widget Icon Stuck Behind Dock (LauncherPro)
cpolek83
Anyone know how to get rid of a widget that has somehow found its way behind my dock so I cannot get to it to move it? I use LauncherPro+.
Thank you!
Yes. I have tried restarting and also resetting to defaults. I've tried to uninstall that widget as well (if it matters, BatteryLife and Signal Strength Pro) and all I get are black boxes that I can't read what it says besides "problem" because it's too far down the homescreen.
Do you or did you ever have the option set for 5 icon rows on the homescreen? Did you add more homescreen rows after the homescreen grid options were added? The most common way for that to happen is to have 5+ rows, add a widget or something to the bottom row, then go back to fewer homescreen rows than you had before. First of all, don't use the option for 5 icon rows anymore. The homescreen grid options are all you need. To fix it, in your launcherpro preferences, go to homescreen settings and set your number of homescreen rows to something higher than it is now. You should be able to get rid of the widget after that. Make sure nothing else is on the bottom row before changing it back to fewer rows.
Good call, i totally forgot about that option
Perfect! Thank you much.
