Check the market for the update. You can now get rid of the status bar icon, set it so homescreen doesn't unlock, and set it so it doesn't revert to default lockscreen.
I don't know if this is part of widget locker, but i found an app on my phone called "custom slider" and it allows you to add custom sliders to your widget locker.
