Help Widget resetting after power off
S
scrapbook
Guest
Is anyone else having an issue with some widgets resetting to the default settings after power off?
If i set up say the extended controls widget from the market as soon as i power off and power back on the widget resets itself.
Switch Pro widget
Power widget
Power control plus
Those three are all paid widgets.
A free one to try is Quick Calendar. Change the settings on this one so that when you press the widget it take you straight to the main calendar rather then the settings.
Then power off and on to see whether it still lets you do that or whether it takes you to settings again.
What widgets do you have at the moment, just out of interest?
