Hello,
I am introducing here my new android widget:
SnackShot Battery Widget
It's a home screen widget that displays the battery level in a snacky way.
SnackShot allows you to take a camera snapshot of a friend or yourslef having your favorite virtual snack from a list of snacks.
The snackshot will then show in home screen and the snack will be your battery indicator by being emptied according to the device's battery level.
The widget allows access to all battery information like battery status, temperature, health, voltage.
It shows also the time you plugged or unplugged the charger, the percentage when the battery started charging or discharging
Below are some screenshots
Let me know what you think
