Help Widget troubles.
Howdy all,
Here's the scoop: I'm a big fan of some of the moto widgets, but when used with LPP the resizing of pretty much any of them makes them all... stupid looking, for lack of a better word. For example, I love the message center (it's probably the one that I'm really getting stuck on), but after I place it, when I go to resize it, it more or less keeps all the content in the same shape and just moves the box around (it does like to smush things where they don't belong though). This of course doesn't happened when I'm using the default launcher.
The question:
1. Is there a way to get these to resize correctly using LLP, or is there a good messaging center widget replacement?
2. Is there another way I could do this I'm not thinking of?
Thanks,
James
Could try changing the numbers of rows/columns under LPP's preferences (homescreen settings). I, like many others it seems, personally use a 10x10 grid.
