Widget wont appear
Epik32
Hi guys,
I have a problem with my phone. I installed an app on my phone but widget for that app wont appear in list of widgets. I tried to reinstall it but it didn't help. Im hopeless.Can someone help me? I have Huawei U8650.
Thanks a lot
Hello and welcome aboard. Unfortunately.. some applications don't have a widget option. I wish most (especially some i use) did have this option. ╯△╰
Welcome to the AF, look around and enjoy. :beerglass:
Be sure to check out the sections dedicated to your Android device and your Carrier.
Also if you want to be able to connect to the Forums from your Android device, be sure to check out the free Phandroid app in the Google Play Market. Cheers!!!!
I found a solution to this. As long as i want to give widgets on screen, I have to install program into mobile memory, cause if it is on sd card, it won't read some program files like widget.
But thanks for help :)
