Help Widgetlocker not working with Inspire?
Saltine713
For some reason, after I installed Widgetlocker on my phone, HTC Inspire, it has the default android theme installed even when I install a different theme.
If I try to add shortcuts, widgets, or a different slider, it appears cut off on the screen. Any idea why?
When you long press on the Widgetlocker screen and choose custom slider and tap the box that says theme-android and change it to another theme it defaults back to the android one and not the one you wanted?
For it being cut off is it positioning them along the top, bottom, sides? What do you have the grid layout set at?
I haven't run into these problems on Widgetlocker.
Never mind, I got it all to work. I had the grid set to automatic. Instead, I put it at 5x4 and it works fine for me. Thanks!
