Help WidgetLocker question
victek
I've been using WidgetLocker for a while. Lately I've been noticing when I use the power button to turn off the screen WidgetLocker will turn the screen back on and display the lockscreen. With the HTC lock screen when you push the power button the screen turns off and stays off, which is what I prefer. I don't see a setting in WidgetLocker about this. I wonder if it could be caused by a widget on the lockscreen? Any thoughts about this will be appreciated.
I havent had this problem ... did you add a widget just before this started? Did you install a new app before this started? I am assuming you already tried a reboot
Thanks for the reply. I turned off the option in WidgetLocker to allow notification pop-ups on the lockscreen and turned off pop-ups in Handcent. So far that seems to have taken care of it.
