Widgets missing
kewlbuddy
Everytime I power off and on/ connect to PC , some widgets like photo contact, digital clock etc are missing :confused:
I dont find them again (long press->widgets) too
Any idea?
Thanks.
Caused by widgets installed on the SD Card. When you connect to a PC it sometimes mounts the card on the PC so the Desire cannot see it anymore.
If you give it a few seconds when you disconnect it will come back.
Also, on power on I find the SD Card is a bit slow to be recognised sometimes.
Hippo
Hoppotech,
I have moved a lot of apps over to the SD card over using App2SD which is great for space creation but I have also noticed things are a bit more 'laggy' (new word?). Do you know if this is a common side effect of moving apps to SD or may I have other problems lurking?
Cheers
Bob
