Help widgets on left side
everytime i longhold on the mainscreen and try to add a widget, it will only add it onto the left side of the screen... and if it is a widget that is long and covers from the left to the right of the screen, it will only show the left half of the widget... but i can put apps there... how to i fix this?
EDIT: nvm figured out it was just a bad version of launcher pro
