Wierd Market Issue
ssanders
When I open the market and click menu then My Apps there are only 4 apps listed. Google Maps, YouTube, Flash Player and Slacker Radio. All 4 of these apps say installed not Update. In the past when I have went to the same place in the market it lists all my apps which is probably about 60. Did something happen to my phone or did a market update cause this.
I am rooted with sideloading enable.
Mine also does this occasionally. No worries.
You say not to worry about it but does this mean my apps wont update because the market doesn't see them as My Apps. I haven't had any updates in a few days.
The only time I have seen this is when I load a new ROM and have just restored my apps from Titanium backup. After a couple hours of being on the new ROM the Market app is able to identify the apps I have and adds them to the list.
Other than that, I have not had what you are describing occur.
When I load a new rom this happens also. I always boot onto recovery and clear cache and it fixes it. It isthe same thing as going under application and clearing the cache under market as previously mentioned. Should fix it
