Help Wierd Screen Issues
CCRAY
Updated to GB and now I notice something wierd when I am in certian apps. I have noticed it in Email, stock web browser and the Facebook App. What I am seeing is that when you are at the bottom or top of a page and continue to pull up or down it it looks as if a faint see through blue color will show up on the bottom or top 1/4 of the page depending on which way you are using the phone. If i am in my email and scroll to the top and a see my first email, if i slide my finger down across the screen and if their is another email above it that is when I see it at the top of the screen. Has anyone else noticed this and what would be causing it??
I think it is distracting when you are using the phone and makes it look as if their is a defect. On facebook it changes the color when you touch the screen. Not just when it scrolls to the end.
yes it does that. You will get used to it. A lot of us have been using GB since March and things like that and the brighter Hard keys as well. you'll get used to it.
I didn't like the brighter hard keys so I disable the lights. Actually I don't even use the hard buttons anymore...Zmooth FTW!!
How do you kill the lights on the hard keys?
I use an app called AdjBrightness, once you open the app press menu >options > and put a check mark in "Lock off button light". Be sure there are no check marks in the screen brightness section. You need to open the app after a reboot to get them to turn off again. The orange bar at the bottom of the screen replaces my Menu, Home and Back buttons.
