Root WIFI/4G still not working on Mobster ROM?
Skelaz
Member
About a month and a half ago, I flashed Mobster's ROM with S-ON and the WIFI/4G did not work so I waited until a later version of the ROM came out and until I was S-OFF. Well, now I'm S-OFF and the final version of the ROM came out and both the WIFI/4G still don't work.
Does anyone else have this issue?
WiFi and 4g work perfectly fine as they should on mobster Rom. Did you wipe the cache and dalvik cache? If that doesn't work backup your data with titanium backup or mybackup root, then do a data factory reset and then wipe all the caches again. ;)
Yeah, I formatted and wiped everything except the sd card. Shall I wipe the sd card as well? Is there a certain kernel that should work with Mobster? Because I really like this ROM, it's a real change from Sense, hope I can figure out why it's not working.
I have 4g and wifi both working fine on mobsters butter rom.
I'm not sure if this was the problem, but I was using the Anthrax kernel from the Midnight ROM when I flashed the Mobster ROM so I flashed another kernel and the WIFI/4G worked.
Changing Kernels without changing the modules that go with it will break Wifi and 4G either flash Power Kernel or Anthrax from Chad's Forum and everything should work fine
