Help Wifi and 3G/4G question
stewdog1
Long time reader, first time poster here.
How does one know if the Epic is using the wifi connection as opposed
to using the 3G connection? When wifi is connected both that and the 3G connection shows at the top. So which one is in control per se? And how can it be verified?
Wifi should take priority if it's connected
I've never seen both icons at the top at once though, FWIW.
You're right. When you're connected to WiFi, the 3G icon goes away. Plus your the browser becomes much faster.
