Houstatlanavegas
just an opinion thing but do you think your home works better or worst on wifi?? cause I think I see dramatic improvement on my phone just a thought
It's a mobile device. They don't need to be able to pull 3+ Mb. It's very rare that you will ever max that out on a cell phone. From what I can tell, my ipod touch can't get too much higher than what my Eris can. So its either a limitation of speedtest mobile, or the network adapters aren't quite as robust.WIFI on eris is a joke. I have a 15 Mb connection and can only get about 2 Mb 3 on a great day over wifi. The 3G is running at about .5 to 1.5 and i much better on the battery. I have full bars according to the status bar. It makes no sense to me either.
The Eris wifi hardware seems to max out at about 5 Mbps. That throughput is the most I've seen with speedtest on my Eris.
