We're a 3 HTC Droid household. 2 of the units haven't had a problem with WiFi, before or after the upgrade. The third unit was connecting fine before the upgrade, but since it's been having issues. It 'sees' the networks (one open, one protected), but when you try to connect to either, it flashes 'Connecting', then quietly returns to the screen, without actually connecting. The settings seem to be the same between the units (wifi enabled and non-airplane). I've rebooted the unit and the router, re-entered the SSID multiple times (although the open network doesn't work either) with no luck.
Anybody have a suggestion?
Thanks,
Terry Ryan
Thanks,
Terry Ryan
