I've searched but have not found a solution as yet. New to Eris and have set up Wifi to connect to home router (Verizon FIOS Actiontec). Successfully connected (accepted WEP) but get very weak signal and then lose connection. I've turned off "Mobile Network" but still have this problem. I am one room away from router and receive full signal on iMac and printer but only a dot under the Wifi symbol on the Eris. Exchanged a Motorola Droid (which received and held full signal -- as did my prior iPhone)) for Eris. VZW tech support clueless and immediately sent me to HTC support. While they tried (had some not very good explanations -- battery not pushing enough power) still nothing working. Any advice/help would be greatly appreciated -- this is the only downside right now. If doesn't work tonight will swap for another tomorrow at VZW.
