wifi connection problem
highfive
Hi guys,
I have an issue with my z1c regarding the wifi:
If I leave the wifi on and leave the routers' area and then get back in the area, the phone cannot connect automatically or manually to saved routers. I can only connect after I restart the wifi on my phone.
Is there anybody out there who's experiencing the same problem or has a fix for this?
Have you got Location Based WiFi turned on in Power Management settings?
It's basically a feature that saves power by turning off WiFi in certain locations. Sometimes it doesn't work as designed.
Try turning the feature off, see if that helps.
Settings>Power Management> Location Based WiFi - OFF
