WiFi Connection
pdogg79
Hey guys.
I'm new to this forum, but hopefully I can get some help.
I have the Samsung captivate and it usually has no problems connecting to WiFi networks but it can't connect to my home network. It recognizes the network but I can't use send/receive any data. My two laptops have no problem connecting to my network but I can't get my phone to. Additionally, my Wii has the same problem. It recognizes the network but can't do anything. Its probably a router problem but their support was useless, so I thought I would try here. Its been driving me crazy!
Thanks
If you're connecting to the router, using the proper security, getting an IP allocated, then it's probably DNS related. I had the same issue with one of our consoles (either the Wii or PS3) and my Captivate. I just changed the Captivate over to a fixed IP and a fixed DNS (I used the free Google DNS 8.8.8.8 and 8.8.4.4, but you could hardwire your own ISP values too).
Hey guys.
Thanks
Is it a Linksys router? Several people including myself have had problems with them. I changed to a D-Link and now both my Captivate and PS3 connect.
There really does seem to be an issue with wireless modem on this phone.
My phone connects to my home network just fine every single time, unless I connect to another wireless network somewhere else. After that, I can not connect back to my home network. I have to turn WiFi off and on a few times, make the phone forget all known networks and re-discover them again, restart the phone and it finally works.
