Yes, this happens to me as well. Lower left corner, it does look like a real issue.
Its weird that this is the only post about it. I guess everyone's using it with a case.
It drops to 1 bar from full strength
I would expect nothing less from most wifi devices without an external antennae.
I replaced my iPad 1 with this Tab 2. The iPad didn't have an external antenna either, yet had no trouble getting wifi in the same places I am using my Tab now, being held the same way I hold the Tab now.
This leads me to believe there is something wrong with the Tab hardware.
Ipad had the same problem, but only if you blocked the middle, ie one handed it in holding middle/bottom of it. That's where their internal antenna was.
Dare I even say it? Ok... you are holding it wrong![]()
Well, now that I got my MoKo case, i am not holding it like that, wifi definately sucks a little, but not enough for me to return, I will live with it. My router is in the basement, I can still take a crap on the other side of the house and search the net. I'm fine.
