Help wifi direct
Do you mean it is not a wireless router at all.?
I have mine hard wired to pc then i connect tab to router wireless
If it not just plug into pc via the usb lead and transfer files using explore and file manager
At last resort install kies and connect via usb this will let you transfer music and images
Router is wireless just pc isnt... its no biggie I just wondered if it was possible as I thought the wifi direct speed when used with s3 was pretty quick, and wondered if their is program for windows so I could have wifi direct on all my sytems...
