Wifi DNS
i know there have been multiple threads on thsi but none seem to solve the problem.
I use a public dns for my internet connection
4.2.2.1
4.2.2.2
So when i connect devices to my router i need to put in the dns but for the droid i dont have that option.
Advanced settings in wi fi doesn't seem to work.
Is there something i need to be doing?
Any reason you're not advertising those addresses in your router's DHCP settings?
For that matter, most home cable/dsl routers do DNS forwarding; set the router as your DNS server, and it should relay.
Anyway, you can set your static address in the Advanced settings; not sure why it's not working correctly. I just tested it, and it works fine for me on my own home network.
