Help WiFi dropping
Hi
My wifi keeps dropping since last night, have the phone almost 2 years, never any wifi issues, restarted router, restarted phone, unchecked and checked use maximum wifi, all other phones and laptop working fine on wifi.. when I have the phone beside the router it has full signal, as soon as i step away it starts dropping until its gone.. downstairs now just under the room where the router is and its on and off at just the first dot..
its on gingerbread..
so annoying
any help greatly appreciated
Oh and check the battery cover in that it is correctly fitted and that the contacts are clean and dust free.
  • Like
Reactions: ral
Well I guess if you've tried everything it must be hardware related. Have you tried the phone at a different location such as a friends house? Are you rooted by any chance?
thanks for the reply, yes tried it in my brothers house, same scenario, only works while sitting at the router. not rooted..
i think its hardware at this point, i cant be without the phone so ill have to live with it til i get a new phone in the next couple of weeks & then get it looked at..?
Sorry. Covered already (read before posting, read before posting, read before posting).
Prolly won't be the solution, but have you tried rebooting the router? One of the other guides had a similar problem and that did the trick :)
I don't know. In this case there is a wifi signal if placed right on the router. So it sound more like a the antenna got disconnected. Since the battery cover is properly seated, the problem is likely after the copper terminals. Was looking at a video on DHD disassembly, and it is not something I would care to try.
i wouldnt have the first clue about setting a static ip address!:D
its been going on for a few days now..
i think its the antenna has come loose...
expensive to fix?
Have you had the phone from new? How long have you had it? HTC offer a 2 year warranty... they should be able to fix it free of charge :)
