Help Wifi dropping. ..
mrteeth
Just started happening a few days ago. I kept seeing the pop up message that says I just connected to my network, which means I somehow lost connection. But it happens really quick. I get my connection back within seconds. Is it the Note or my router? Thx.
This also happens to me but after I press the 'try to reconnect button it seems to connect. Occasionally it happens on my Galaxy Note (I) as well. I attribute this to Jellybean 4.1.2 as I dont recall this happening when both devices were ICS.
I have this happen to me on both my Note 2 and Note 10.1. But it's not signal dropping. It keeps bouncing between my 2.4 and 5.0 GHz networks. My Wi-Fi signals are strong and I'm browsing and checking emails without issue.
I had this happen before. It kept trying to obtain an IP. I dedicated an IP address in my router for the Notes MAC address and haven't had a problem since.
I solved it by resetting my router. That seemed to fix it. It hasn't happened again. You need to reset your routers once in awhile
