Help WIFI error after froyo upgrade
Legacystar
wifi will not turn on after official froyo upgrade. i just get "error" is there any way to re-install the update? i conencted to mini kies again but it doesn't allow me to re-update.
Before reinstalling the 2.2 upgrade, I'd go into both wifi and network settings and have a careful look to see if everything remains as it was prior to the upgrade.
I'd even take the trouble to go into the application manager and clear all cache and data and defaults on wifi and network and everything related, reboot and then reconfigure, just to start fresh.
Then, if no joy, consider a reinstall. If you do the reinstall first, you may just import the problems to the new installation.
You have one option of a master reset, which would mean you would lose all the applications you had installed.
When you say you get error, do you have WiFi enabled and are trying to connect, or do you have it disabled and are trying to enable?
No when.I attempt to turn on the Wifi it says error
I had same problem today. I did a reboot on both my home internet and the cell, turning the cell on after I knew my wifi signal was up and operational in the house. Clicked on wifi again and everything is back working again. Not sure what caused it but is ok now
