Slug Check six! VIP Member Sep 4, 2016 #2 By "won't turn off" do you mean that the on/off toggle in Settings/Wifi has no effect? Can you describe any error messages seen when you try to connect to a wifi network?
Amal albert Lurker Sep 15, 2016 #3 Yes WiFi on/off toggle has no effect and WiFi settengs is not responding
mikedt 你好 VIP Member Sep 15, 2016 #4 Try restarting it, if that doesn't, try factory reset, and if that doesn't either, it's probably faulty, repair or replacement required.
