DWILSON48625
Ok, so you rooted your phone, installed a killer ROM, and want to WiFi. Heres how to make the app work.
THIS WORKS FOR THE PREVAIL AND PRECIDENT
Download the WiFi For Root Users from Play (meuller, lemons, buxton)
Open it
Tap menu, settings, "change device profile"
Select Galaxy Indulge (there is no option for the prevail or precident)
Tap back
Tap "change setup method"
Choose "samsung soft tap"
Tap back.
Reboot to be sure it takes.
Open app
Tap the icon to start tether.
Sometimes it gives me trouble starting. Im not sure what causes the issue, but usually a restart kicks it into gear. You will know its running when you see "hotspot activated" icon and the wifi icon pop up.
Hope this helps those who are confused when they open it and nothing works.
Open it
Tap back
Tap back.
Open app
