Help Wifi goes dead
ParaGuy
I have a problem with the Boost Mobile Samsung Galaxy SII. I connect to any wifi hotspot without a problem but after an undetermined amount of time, the phone just stops receiving signal from the wifi connection. If I disconnect and re-connect the wifi works great again. It seems to go dead after the phone goes to sleep or in powersave mode. Is there any known fix for this problem?
Thanks
Go into the settings menu select WiFi then hit the menu button and select advanced. make sure the keep WiFi on during sleep is set to always.
My phone does the same. If i don't turn the wifi back off and on, it won't connect to the router.
Serious bug in my opinion.
Mine does the same. My Settings are WiFi Always on during sleep, but still after an undetermined amount of time, the phone just stops receiving signal from the WiFi connection.
i bought boost mobile galaxy s2 4g from best by right away it had wifi and browsed the internet while not being activated with boost .....few days later it shows whifi cnection but will not browse internet of go on to google market. so i reset factory on it then downloaded and set up the phone the way i like wifi and interner was working another 2 days later wifi is connected but when i try to go to internet its not working and google market is not working. i gueess my question how do i fix it and does boost some how after few days able to prevent you from using wifi browsing if you didnt activate the phone
Yep, not the router settings, I have tried this on multiple security type settings and it does the same thing with every router I connect to, at work, the coffee shop etc. The keep wifi on during sleep setting doesn't help either. Is there a really good app that will work to keep a wifi connection alive? I'd probably use it even though I'm sure it would eat up your battery life.
I never had this problem. When I set mine to always be on, It stays on. I can also confirm that it does eat the battery. When I keep it active all the time my run time will drop to between 12 to 14 hours depending on use. When I let WiFi sleep when the phone is idle I can for a up to a couple of days.
Still no fix for this problem. I know that a lot of people are having this problem with the Samsung Boost Mobile SII but there seems to be no fix in site. If I turn off wifi and then turn it back on it works fine but then if I just leave it connected, the wifi connection goes dead. I should also mention that I am using the stock software and it is un-rooted. Can anybody confirm that they are not having this problem on a rooted / mod'ed phone?
