Help WiFi help, please! Last chance saloon for my S3
erikab922
I am having terrible trouble connecting to my home WiFi with my S3. I have three laptops connected and my neighbour can connect straight away on his iPhone through the wall. My old HTC Touch can connect fine.
So far I have tried (all from this forum):
- *#0011# and turning off the WiFi power saver
- forgetting network, rebooting router, rebooting phone, etc.
- changing encryption from WPA2-AES to WPA2-AES+TKIP
Sometimes I get authentication errors which is bizarre as the password is completely fine, as other times I get the dreaded 'Network disabled. Poor connection'. Everything connects fine except this phone.
I am at a total loss as to what else to try. This is my second S3, my first one had the same problem but the *#0011# fixed it; however, the SIM reader was broken out of the box so I had to return it. Not having much luck with the S3!
Android version 4.1.2
EDIT: 11 hours later and I finally sorted it. The thing I had to do to get it to work makes no sense, but here goes. I asked my neighbour if I could try connecting to his wireless network and, shockingly to me, I was able to connect. Grrr. So I removed all security on my router for a few minutes, and when my network was open I was able to connect. Interesting.
I chose Forget Network. Then I stepped up the security to WEP, and again I was able to connect. I forgot the network on my phone again and put the security on the router back to the exact same setting I started with, WPA2-AES+TKIP, same password, and this time it connected straight away.
To one of the posters below, I was unable to connect via WPS, I got the same problems as when I tried to connect without it. I also tried manually amending the connection configuration to use a static IP address, etc but no dice. Only thing that worked was the palaver above.
I get the authentication error @ times but, a visit to the WI-FI settings & pressing CONNECT takes care of it.
I'm hoping your problem is this simple to remedy, although doubtful, but, for troubleshooting purposes, just trying to rule out the possibility before proceeding.
Keep us posted on your results!
