Help wifi help please my optimus3d
ok i have an unrooted year and half old optimus 3d. model 925g. my cell service was susspended 3 weeks ago. Ive been using wifi the whole time to e-mail facebook etc. yesterday the wifi just stopped working. it reads as fully connected but i cant access anything on internet. I tried soft reboot no luck. factory reset no luck. Prior to factory reset. i went into a shop it had wifi i was conected. no service. however as soon as i agreed to the shops little licensing blurb on my browser it gave me full wifi access. At home after factory reset i tried resetting router and using password to my home router. it trys authenticating but just kicks off as disabled. Im not that tech savy please help!!!!!!!!!!!!! must be a way to fix this. not ready to give up. need wifi to work. Frustrated!!!!!!
Hello itchydroid. Welcome to the forums.
There are a few suspicions that come to mind, not the least of which is the sudden difficulties arising because of encryption issues. If it was working ok, then you did a reset and found a connection after a gateway/licensing agreement at a public hot spot, it's possible that the public wifi has snagged priority and needs to be "forgotten" in the settings list of available networks in your device's wifi menu area. Just hit every network except your home one, and when the prompt comes up to "forget," hit that for each one.
Also, when a reset is done, especially in an older device, the encryption may revert to one of the older systems, most likely WEP or WPA instead of WPA2 (of course, if it matches your home router it won't make a difference and a different reason for dropping connection needs to be investigated).
I'd reset the home router, either by internal configuration choice or a special button on the case of the router, or by unplugging its power source for a few minutes. Then I'd reconfigure everything both router and phone.
I know this might sound stupid, but have you rebooted your phone.
I've a problem like that on my Optimus 2X where the Wi-Fi wouldn't even turn on, when I rebooted it was gone.
Seems like a weird glitch in the software, never happened to me again when I updated to ICS
