Hello, I just bought a Galaxy 8.0 tablet, and I am about to return it. Here is the issue. The wifi connects to the hot spots but not at my house . I have time warner cable with an ARRIS router. All my other devices connect to wifi but not the Galaxy. I called samsung support and they had me change the settings on the router to channel 6 or 11 (which I did) also change the security to WPA2-PSK from WPA/WPA2-PSK and the encryption to TKIP/AES. The galaxy MAC address shows in the "Wireless client list " because it actually connects to the router. However when I try to load a page the progress bar goes about 1/3 of the way and then it stops, then I get an error message that says "page not available, check address or try later".
I need to know if anyone else is having an issue with this .. or if they have a fix..
thanks .
thanks .
