Help WiFi Help
laselva91
The WiFi capability on my phone is broken. I cannot even turn on WiFi anymore and I do not understand what the problem is. Every time I attempt to turn it on, it just sits at the screen and says "Turning WiFi on..." and does not progress any further. I have tried resetting my router and modem at home, restoring my phone to factory default, using 3rd party WiFi apps, and taking out the battery, SIM card, etc. I am planning on taking it back to the store I got it to see if they can help, but in the meantime, does anyone have any suggestions at all? I'm stuck on this one.
Edit: My DATA still works..I can access the Internet, Market, etc. using my data plan, but this is eating up my data, which is not unlimited.
have you tried going to settings>wifi and then searching for wifi connections. it may be trying to "connect" when it hasnt searched and found yet. weird, but i have gone into my wifi settings in other areas and found that it had nothing to connect to until i told it to scan for new networks
