Help wifi help
ron316
i need some help when i use usb cable to use phone to tether for internet i get prompt network security keywhere do i find security key on samsung gs4 and set it up or is it better wireless wifi with phone thanks
I found your question somewhat hard to understand but using wifi tethering works very well so I suggest you try that. You will need to configure a hotspot password so everyone cannot connect to it but it is very easy.
