SpiritOTG
Hello guys, I have used apps like EasyTether and currently the pro version of PDAnet (I like it much more than EasyTether).
The thing is, is that no matter what I have tried, I can not ever seem to get the WiFi Hotspot to successfully allow another device to connect. Most often, I am presented with "Failure to obtain IP" on the computer's or PS3's end.
I have tried using the WiFix Manager before, and to no avail.
SIDE NOTES:
Boost Mobile is my Carrier
2GB SD EXTERNAL
Rooted Device (WiFi did not work before root either in the same fashion)
Has anyone else encountered this issue with their Optimus F3? Has anyone fixed it? If so, what was the process you did to make it work?
All the best and thanks for reading
SIDE NOTES:
2GB SD EXTERNAL
. For some reason when the hot spot is active and I put a tablet or laptop to sleep. When I pull them out of sleep the connection is dead. Like its still connected but I must forget the hot spot and reconnect. Weird ! I never had that with any other tethers. Its also not my connection or phone.. Because my phone works fine and I have 6 full bars. Also notice faster speeds on a tablet v3 computer. And I have all my pc updates turned off. Nothing is updating.
