You can use apex or any other launcher.
http://androidforums.com/one-sv-all-things-root/727477-boost-hotspot-without-root.html
WiFi tether for root users. Yes you need to be rooted. Last time I looked I didn't see it at play store. Google it. I know for a fact ver. 3.2 beta works on ics and jb.
Also there was a thread about tether w/o root on this forum using apex launcher. You can try that.
is this file for JB. i just done the ultimate guide to everything for this phone, reinstalled wifi for root (even though it no longer showed up on playstore) Set it on ICS/JB Lan 1 setting. got no errors, showed up on networks list but no data transmission
edit: i got wifitether for root to work on rooted s-off new JB stock rom to work by changing profile to Lan0 and checking on the option send netd max client cmd.
Ok, I've got a problem. I can use the wifi hotspot to connect to my pc and laptop. Both connect just fine. It won't work with my tablet though. It says connecting, then goes to obtaining ip then back to connecting. It never connects.
have you confirmed working internet on pc and laptop? have you done any recent changes to your encryption settings on wifi? if yes you must delete connection profile(forget) and attempt to re-establish a connection to get the password prompt again. Ive had mine do something similar when i changed connection password to wifi and didnt update tablet
http://db.tt/mPVGsGjy
This version of WiFi tether should work with tablets too just change profile to generic ICS/JB (wlan0)
thanks that works with my nook tablet running CM10.1.2 it's the first thing to work with the nook tablet. Eventing else sticks at authenticating if I have wpa2 active or at obtaining ip address if I don't have it protected.
