Hi,
I have an issue with my Samsung Galaxy SII phone's wifi connection. I have this phone since Nov 2011. Until couple of days before it was working absolutely fine. But now although it's showing green Wifi symbol its not showing any wifi networks and also I can't turn it off. When I checked the wifi under settings it's not completely off there is difference between the Bluetooth off and Wifi off. Though both are greyed out but still there is a difference in the brightness of the off status. Also when I tried to turn on wifi under settings it shows the message 'turning on wifi' but nothing happens however the wifi symbol becomes green.
The problem is now I think though it does not show wifi networks but still remains ON so battery dies after couple of hours.
Please can some one advise what could be wrong or is there any way to disable the wifi option permanently.
Thanks.
....Mansawant
Thanks.
....Mansawant
