Help WIFI Issue
Hello all, having a problem with my X and I thought i'd look for suggestions. I've had it since launch, and have used it over Wifi a few times without issue, but only for short periods. Last night, I was wanting to download a large file so I turned on my Wifi at home and started the download. Noticed after a few minutes that it had stopped, and went to looking into it a bit.
Turns out that within a couple of minutes of connecting to my network, the X just stops recognizing my network. It still says it's connected, but you can't browse the web or anything. If you turn off Wifi and turn it back on, it reconnects and works fine again...for a few minutes, then it stops again.
I know it's not my network itself, as I have used a dozen devices or more on it without issue, so it's something the X is doing that is different. Any tips?
