Help Wifi issue
Robert7107
I have wifi at home but i keep getting disconnected. My girlfriend has the exact same home and no issues. Note 3 att
Do you get disconnected if the phone is within a few inches of the router? If not, you have a warranty exchange problem - the wifi antenna in the phone isn't connected (or the wifi radio is shot).
Yeah you might want to go to ATT and ask about a replacement device or a new one.
Does this happen with all Wifi's or just yours?
do you get an error message with yours?
mine keeps saying my "wifi connection is unstable" or something along those lines
Go to Settings > Wi-Fi and tap Menu > Advanced and then uncheck Auto network switch. That seems to have helped some people.
Try turning off the Note 3 and your router for a few minutes and then turn them both back on again.
Go to Settings > Wi-Fi and long press on the problem connection, then tell the device to forget it and set the connection up again
If this does not work then
Go to the dialler
Type *#0011#
Press menu capacitive button
Go to wifi
Turn of power saving
Go to the dialler
Type *#0011#
Go to wifi
Mine also disconnects randomly from my wifi. Says wifi connection unstable. But if I connect to it again it works fine.
Going to try the power savings feature and see if that fixes it.
Wondering how much more juice it will drain from my battery though.
