Hello,
i now have a wifi problem,
Ive had the phone 3 days, the first two days the wifi was great, but today it is just not working.
All other laptops and pcs and phones work fine with wifi just this s3 is not.
The first two days when i turned wifi on - it connected automatically (after the initial connection asking for the password) and every thing was fine, but today when i turn wifi on no auto connection to the hub and no connection at all.
When i click wifi- the list of local wifi connection points come available, so i click on mine (which is repeated twice - one has "wps available" under it) and it says connecting for a few seconds and then it just returns to scanning, it will not connect and it will just keep scanning over and over and over again till wifi is turned off, Also under my wifi point name it says "Saved".
I press forgot network (on both of my repeated networks) and they just reappear.
Any help would be great
Thankyou!
When my phone sleeps for a duration of time, upon wakeup my Wi-Fi shows it is still connected but zero data can be transfered. E-mail/playstore/browers can not connect. I have to turn wifi off and on again for it to re-establish. This causes my email pushes not to come through. I've played with some router settings, but have not forced the phone onto 2.4 or 5ghz. WMM is enabled as well. I have now just enabled the wifi sleep trick in the service menu, and I had the keep wifi on during sleep already on in the regular menu. Now my screen won't time out after the service menu trick. I called for a handset replacement and got the speech about clearing cookies and wipe phone data. Sigh... So I have to remember to turn this on every reboot and make sure to turn my screen off each time. Regret is sinking in, as I told my self never again after a Behold II. T-mobile please get a good HTC phone, I think the S3 is going back!
anyone have issues with just the wifi DOWNLOAD speed?
mine floats around 500-900kbps... upload though, it normal. 6-8+Mpbs.
This is a common know issue with android devices. Try wifi fixer from the Google play store. That worked for me.
This is exactly the issue I am experiencing with my VZW GS3 connected to my home Apple Airport Extreme. None of my previous phones (iOS and Android) had this problem, but the S3 is having it intermittently. After not using my phone for a while, I'll turn the screen on and have no data connection. However, it still shows it is connected to my WIFI, but no data will go through. If I go into WIFI settings and try to re-connect, it will not do it. Simply turning off WIFI and turning it back on corrects the problem immediately (it will re-connect to my WIFI automatically after doing this). I mostly notice this after checking my phone first thing in the morning after waking up. If I don't have my phone plugged into the wall charger, my phone will lose a lot more battery because it is on the 4G network instead of WIFI (even though it shows I'm still on WIFI).
So far, it hasn't been a major issue for me, but definitely one that needs to be addressed.
Try the SSID split I posted, let me know your results. So far it has been good here.
