Help Wifi issues question..
So I think that Wifi issues with the DX are well documented, but I haven't seen the issue that I have.
At home, I can connect to my Secured Wireless network without issue. It never drops the connection, uses the connection exactly as I would expect.
At work, we have an insecure wireless network. I sit directly underneath the access point and I see the network in my list of available networks with full strength. When I try to connect into it, sometimes it connects and othertimes, it just tries to and doesn't. Either way, once it does, it will drop the connection about 5-10 minutes later and I'm stuck starting back over again. I talked to our IT guys here and they say that the network is pretty standard and there shouldn't be anything special that I need to do. Just wondering if this might be related to the issues that the DX was seeing with wifi.
I am now running Gingerbread, unrooted, but have seen this issue on every ROM that I have ever run on my DX while rooted and on FROYO.
Thanks in advance.
There could be one or more of several reasons for poor connectivity on one wifi network over another.
I first suspect the channel the poor connection's router is operating on.
7 and 11 seem to be reported as the two best. Most network admins don't pay much attention to the channel number, and many even change them routinely as a security measure (not needed), often borking good connectivity or accidentally improving connectivity.
